Need advice on purchasing best graphics card under $550
Tranman13195
I'm looking to upgrade my graphics card from a 560ti and my budget is around $550. I've been looking into the 7970 lightning and the sapphire x 7970. I'm currently using dual monitors at 1920 x 1800, with i-7 3770k. I'm basically looking for the most bang for my buck in a single gpu. In the future i am planning to overclocking my gpu.
tonyjones
97
I'd go with the GTX 670 which you can get for around $300! Especially if your gaming at 1920x1800
lehtv
11,897
74
I upgraded from 560 Ti to a Sapphire 7950 and overclocked it to 1100mhz on stock volts. It plays everything pretty much perfectly - there's no need to spend more money on 1080p. If I were you I'd get the Sapphire 7950 for $280 AR and save the rest for later upgrades.
Also, what is your CPU?
Pedroc1999
305
I disagree with the GTX 670, The 7970 can be overclocked past the 680 and is much better value for money
3DVagabond
11,951
204
Especially when you consider that "decent" 670's with a top quality cooling solution are still going for closer to $400 than $300. They are still limited to 2Gig of RAM too, unless you want to spend even more.
On a side note, I can't believe that they are still advertising the MSI 670PE as, "Triple Overvoltage: adjust the voltage of GPU, memory and PLL to unleash the potential of graphics card." Correct me if I'm wrong, but wasn't that feature axed?
sze5003
14,320
683
I have the vapor x GHz 7970 I like it a lot. I think I paid $450 for it. I've had no issues really other than my monitor not being 120hz
3DVagabond
11,951
204
would the sapphire vapor x ghz edition worth $600
http://www.newegg.com/Product/Produc...82E16814202005
Not for gaming. No need for the 6GB frame buffer. Doing some OpenCL rendering of scenes > 3GB though would be a different story. If you are looking for a premium model card you'd be better looking at the Asus Matrix Platinum (if you can find one) or the MSI Lightning, or even the 3GB Vapor-X. That would be the order I would put them in. The Lightning is the only true 2 slot model, if that's a factor for you.
