Need advice on PSU
Beliar
Hello,
I'm buying the following for my new build :
DFI Lanparty nforce4 Ultra-D Mobo
Amd a64 3200+ winchester
OCZ 3200 Platinum rev2.
BFG 6800GT OC
Sound Blaster Audigy2
+ drives, fans, etc.
I can't decide what PSU to get...
I was gonna buy ENERMAX 485W EG495 AX-VE Noisetaker 485W w/ active PFC, but i'm not so sure now because I think a single 12V rail is probably better.. This one had all the features I wanted, pff only if it a had single 12V rail. I need suggestions and preferably ones w/ active PFC...
I have a Tagan 480W in mind actually, but the only reviews i could find about it were out-dated(pci-e was not a subjet then), so I don't know if the unit is revised has a 6 pin PCI-E connector now, plus I'm not sure about its stability in a rather heavily o/ced system (3200+@2.7 ghz, 6800GT@ultra,etc..). Can anyone who uses this give me some info?
Other than that, I would be really happy to read your suggestions. (I can presume many will suggest OCZ Powerstream but I think $140 is a bit steep, the Enermax mentioned above is priced ~$100 and Tagan is ~$80. I would buy it though if I was really convinced that it worth it)
The Tagan is a great PSU tons of clean stable power. It's basically the same as OCZ, but less bling and prolly quieter. The downside is there have been recent reports of little to no tech support from Tagan, it was great initially...
I would prolly go with a Seasonic Super Silencer or Tornado over any Enermax.
