- Jul 26, 2007
- 397
- 0
- 0
Need some advice on overclocking. I currently have an ECS P4M900T-M Version 1 Motherboard. Was able to pick it up cheap as I am a college student. Currently have a P4 641 Cedar mill 3.2 Ghz Processor and looking to move to an e 2140 as they aren't real costly. I'm new to overclocking and started playing in the BIOS with Bus Speed. The only option I can see for speed is the system speed at 200 Mhz. If I go above 220 mhz. System locks up. I don't think this is a heat issue, so what would cause this brick wall. Also you can raise the procesor voltage slightly with the BIOS settings as well as slightly raise the voltage on the ram. Does anyone know why I can't go past 220 MHZ with my BIOS settings???? Any help would be highly appreciated!!! Thanks!
