I have a TMC AI5VG+ motherboard and recently replaced my CPU (AMD k6-2 350MHz) with the AMD k6-2+ 450MHz processor. I had a bit of trouble getting my system to boot and luckily I had read on the AMDZone that some older motherboards will not boot with the + CPUs unless the clock is set at 300MHz. Doing this (through jumpers) I was able to boot and load windows.
I also added UARTs program k6clkini.com to my autoexec file that allowed me to change my multiplier through his k6clkwin program in windows. I can set it all the way up to 5 (5 x 100 MHz) to get up to 500MHz. When I select 5.5, I either lock up or sometimes get a blue screen.
This happens with the Vcore set at either 2.0 or 2.1.
I was wondering what is the best way to get it to go up to 550 or even maybe 600MHz. Right now I have a KWI HSF (ball bearing) combo that came with my k6-2 350MHz cpu from motherboards.com. I have read that inexpensive HSFs work just fine with the K6-2+ CPUs since they are made with 0.18 micron die instead of the typical 0.25 micron of the k6-2 CPUs. Would putting a better HSF onto the K6-2+ prevent the lock up I am experiencing at 550MHz? I have read post where others suggest the Globalwin FOP32-1 for this CPU.
Also, while I am on the topic, both the old and new CPUs have that metal shield on them with the etching of the AMD chip info. Do I need to put some form of compound between it and the HSF (like grease)?
Please be kind, I have never OC'd before and have minimal experience installing CPUs and HSFs.
Thanks for your help!
