Need advice on HT speaker configuration.
50
2,717
Hello, currently I have this speaker setup. I just got a 6.1 receiver, and want to add another channel. I was thinking about buying those speakers and taking the center channel and putting it in my main room and leaving the rest in the other room. This would work out perfectly since the center channel is broken on the receiver in the other room (so I would have a 4.0 setup in there). However I was looking for speaker wall mounts and couldn't find any. The only wall mounts I could find were compatible with the sattelites only. I was thinking about getting the BT332's (does anyone know how much in american dollars this would be?). Does anyone know if there are wallmounts for this speaker(model number SS-CN230)? But then I was thinking, in the future maybe I'll want 7.1. Those speaker mounts come in pairs as well. In that case, I would have to take 1 sattelite from that 4.0 configuration. Would it sound terrible in the other room with a center speaker as a right channel and the rest regular sattelites? Also it would be a pain if I ever go 7.1 to have to realign the speakers and drill new holes in the wall and have one hole in the middle of nowhere. What do you think I should do?
Howard
47,982
11
You'd probably be better off upgrading the speakers, instead of adding more crap.
By the way, the ".1" means LFE - i.e. the subwoofer.
spidey07
65,469
agreed. same model speakers all around is your goal.
