The ultra is costly but you get what you pay for,the card is built alot better than the others but the fan is faster and makes more noise.I use a 3 1/2 inch (speciel bracket built) fan blowing on the card with the on board fan unpluged.
I had both cards and here are the 3D test results:
3D test GF2 32 Direct3D 245.4453 MPixels/s
3D test GF2 Ultra 64 Direct3D 317.9351 MPixels/
PS 2dvideo is not the fastest on the market but it is good enough for the programs that you will run in 2D mode.
I played DFLW (Delta Force Land Warrior)wwith the GF2 Ultra and I was in the prone position and seen ant,s crawling across the ground it was so clear 🙂.Money is not the most inportant thing in the world;it is the only thing.
