need advice on gaming PC
Discussion in 'General Hardware' started by krrice, Nov 4, 2012.
  1. krrice
    krrice Junior Member
    May 2, 2012
    12
    Hi everyone, I am building my son a gaming pc and would like some advice.
    I originally did not want to spend no more than 600.00 on all items but I am at about 800.00.Any advice will be greatly appreciated..
    1.He plays online multi-player FPS games mostly
    2.budget is 600.00 to 800.00
    3.USA / there is a microcenter close by
    4.I do not really have a preference but the two systems I've built in the past have been AMD
    5.Already have 19" 720p and monitor that I will be replacing soon,keyboard and mouse,case
    6.May overclock if necessary
    7.Building before Christmas
    Here is the list of hardware that i have put together
    i5-3570k
    ASRock Z77 Extreme 4
    gtx 560 ti
    gskill Ripjaws 8gb
    Hyper 212 EVO CPU Cooler
    Crucial M4 128 GB 2.5 SSD
    WD Caviar Black 500GB 7200 RPM
    OCZ Fatality 750W PSU
  2. Loading...
    Similar Threads - advice gaming Forum Date
    Need advice on Gaming Rig General Hardware Jul 5, 2016
    Ultimate Gaming Build... Any advice? General Hardware Nov 7, 2015
    6700k New Gaming Build Advice. General Hardware Oct 30, 2015
    need advice with my first gaming PC General Hardware Oct 13, 2015
    Advice with a new build, some games General Hardware Sep 8, 2015
  3. lehtv
    lehtv Lifer
    Dec 8, 2010
    11,658
    8
    At a budget of $800, your best bet is to upgrade the monitor to 1080p then spending $650 on the PC itself
  4. OmegaSupreme
    OmegaSupreme Member
    Nov 3, 2012
    61
    I suppose it's relevant to know which games he plays.
    Also, if you have an MC close by, they have bundle deals where you can chop $50 off of the board.
    I'd suggest you get a different brand PSU. OCZ isn't the greatest, nor is it the most reliable.
    Brands I'd suggest to you: SeaSonic, PC Power & Cooling (most are built by SeaSonic), Corsair, Enermax, and Corsair. However, this depends on your future additions to the machine. If you're only going to run 1 video card, you don't need a 750w power supply. A quality 550w would do just fine.
    Out of curiosity, what's the 560Ti running you?
  5. Dijeangenie
    Dijeangenie Senior member
    Sep 11, 2012
    253
    He said online multi-player FPS - so that's likely to be fairly demanding games, especially as if he plays them seriously he will want constant 60 fps
  6. krrice
    May 2, 2012
    12
    I can get the 560 ti at microcenter for 209.00 after rebate
  7. Ken g6
    Ken g6 Programming Moderator, Elite Member
    Moderator
    Dec 11, 1999
    12,346
    225
    Hm, so you want a nice $210AR graphics card? This XFX 7870 Double-D beats a 560ti every time (except for low-res Starcraft).
    I assume you're bundling your CPU and mobo at Micro Center. I wouldn't get the Extreme4 over, say, the Pro4, unless you're sure you're going to crossfire or SLI at some point.
  8. mfenn
    mfenn Elite Member <br> Currently on <BR> Moderator Sabb
    Jan 17, 2010
    22,403
    Agree on both counts.
    OP, Here's a build for $800:
    i5 3570K + ASRock Z77 Pro3 combo $225 @ MC
    Geil DDR3 1333 8GB $29
    7850 2GB $185 AR
    WD Blue 1TB $70
    Lite-ON DVD Burner $18
    XFX Core 550W $60 AR
    Antec One
    $50
    LG 24" 1080P $160
    Total: $797
  9. lehtv
    lehtv Lifer
    Dec 8, 2010
    11,658
    8
    If he plays them seriously, it's not essential to have a powerful GPU that can run the games at 60fps on high settings. Low settings are fine for competitive FPS and usually result in better visibility
