My current setup is a set of Logitech Soundman X1's (2.1) running on onboard sound from my Epox 8k7a. That isnt such a great setup. At full blast you can hardly feel the base and it distorts quite a bit. I play a good amount of games (mostly CS) and listen to a lot of music on the computer. I use my computer as a tv, stereo, dvd player, etc. I live in a dorm room most of the year, so I think I should stick with a 2.1 setup because of space limitations.
Anyway I am looking to spend ~$100 for a nice audio upgrade. I know my onboard sound should probably go, and my speakers are pretty weak. Here is what I'm thinking about...tell me what you think:
Boston Acoustics BA7500G 2.1 ~$50
or
Logitech z340 2.1 for about the same price ~$46
or
Yamaha 80W YSTMS50W 2.1 ~$90
Soundcard:
Turtle Beach Santa Cruz ~$60 or SB Live 5.1 ~$30
Anyone have any input on what setup I should get or any other suggestions. The above are just ideas...feel free to suggest others. I want a powerful set of speakers with good base. I know wattage ratings aren't everything...thats why Im asking you audiophiles to help me decide. Is a great soundcard like the santa cruz going to make that much of a difference, or do I buy a cheap soundcard and splurge on something like the z560's (although those are out of my price range) I basically want to know how can I get the best sound for my hundered or so dollars...
Thanks in advance!
-Qwertybk
or
or
Soundcard:
Thanks in advance!
-Qwertybk
