I am keen to buy a Lian Li PC-6070.
The version I see at my local store has a 120 mm intake fan at the front and a 80mm exhaust fan at the back of the casing.
(Question 1🙂 Is this enough to cool the interior of the case?
My OCZ power supply also has an intake fan that pulls air from inside the casing and exhaust from the back of the power supply. (Question 2🙂 Does this help to circulate air inside the case too? I am hoping this serves as a second set of intake and exhaust fans.
(Question 3🙂 The Lian Li casing has an opening on the top of the casing that I can install another fan, should I do so?
(Question 4🙂 If I go ahead with the purchase, chances are I will re-mount m Zalman 7000-Cu HSF, is it worth to buy the arctic silver 5 thermal paste or should I just use the zalman bundled thermal paste?
Any suggestions are welcome too.
