Need advice on building new rig
Mulmaster
4
Hello
I would greatly appreciate some advice on the first PC I plan on building. Just to let you know I do not plan on overclocking or using a RAID setup.
I am looking for suggestions, feedback (good or bad), and whether there are compatibility issues with the hardware I selected.
I also would I need to install more fans then the default (power supply, processor, video card, chipset)?
Thank you!
Mulmaster
Motherboard - ABit KR7A-133 VIA KT266A (think it has a chipset fan)
Processor - AMD Athlon XP 1900+/266 FSB Processor CPU - OEM
Hard Drive - Maxtor EIDE Hard Drive 60GB 7200RPM
Video Card - Gainward/Cardexpet GeForce 3 Ti200 128MB
CD Writer - Lite-On LTR-24102B-02 24x10x40 CD-RW
CD Reader - Lite-On LTD-163 Speed - 16X DVD ROM 48X CD-ROM
Case - ANTEC Server Chasis (Workstation Tower) Model SX1040
Heat Sink - ALPHA PAL8045T
Processor Fan - Panaflo 80mm 4 Pin
Sound Card - Creative Labs Sound Blaster Audigy Xgamer
Memory - 2 x Crucial 256MB DDR PC2100, 184-pin DIMM
