Need advice on a video card... for about $100
McArra
3,295
Originally posted by: SneakyStuff
the 4200 TI isnt a DX9(x) card, thats the one tiny flaw.
Fx5200 can't even run DX8 smoothly, so no matter if it has DX9 as it won't be able to run them.
rimshaker
722
It might be tiny at the moment for some.. but it'll become a bigger drawback as the year progresses. DX9 support is a must IMO. 5600 Ultra rev2 can be found once in a while for $100...... like this past black friday sale at CU.
dxpaap
572
OK I'm confused - looking at Pricewatch
Radeon 9600 Pro 128mb = $130
Radeon 9500 Pro 128mb = $188
going by price 9500 pro is a better performer then the 9600 pro ??
Radeon 9600 SE 128mb =$85
Is the Pro vs the SE performance make a signifcant diff for a budget system that will run "Max Pain II" (which says it uses DircectX9.0) ?
thanks
modedepe
3,474
thanks
The 9500 pro is a better performer than the 9600 pro, but is definitely not worth $58 more. If you're looking at spending $188 then get either an fx5900 or a 9700. If you're looking at spending $130 though, then consider getting a 9600xt, which is $132 after rebate at compusa currently, which is a great deal. And yes the 9600se vs the 9600 pro is a big differnce. The se is a MUCH slower card. I personally wouldn't touch it.
Nov 22, 2003
36
ASUS 9600SE, good card, good reviews, VGA, DVI, s-video. No passive cooling either, it uses a fan. Card outperforms the geforce fx 5200 ultra. This is just a dulled down version of the 9600 XT.
The 9600SE doesn't look that hot against a 5200. http://www.digit-life.com/articles2/radeon/asus-ati.html
Personally I'd go for a 9600 Pro. Getting a low end card like a 5200Ultra, 9600SE, or a DX8 card like the 4200 is kind of silly. They are have problems with advanced games, why not spend a bit more and get a good 9600 or even more and get a 5700, and have a good card. If you're going to upgrade, why not do it right?
NEVERwinter
766
Not everyone play games :)
look, DaveJ412 can stay with a GF2pro for that long... I think a 9600 or Ti4200 will fit him enough
Viper96720
4,390
LOL my brother still plays games with a gf2gts card. He has been playing call of duty with it. But he told me it takes awhile after he shoots to hit the enemy. I recommended he get a 9200 it'll at least be better than the geforce 2. Long as it plays the game normal settings 800x600 he's happy.
