- Nov 22, 2009
- 2,383
- 11
- 76
Right now, I am still using a XFX HD 6870. I am looking to upgrade the GPU. I have always used AMD mostly, but have no problem with Nvidia. So either recommendation is fine.
I was actually looking at the HD 7870 tier performance. The PC is using a AMD 8120 / H80. I really don't need to upgrade the CPU right now, it should be fine for another 6-12 months hopefully. But a few other items takes priority over a CPU. My power supply is a Corsair TX750. http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021
The games will be Bioshock Infinite, COD Series, Far Cry 3, Battlefield 3, and all the Crysis games as well as games like Starcraft II and Diablo III. And probably new games as well that is not yet launched.
The PC has 8 gig of 1600 Gskill http://www.newegg.com/Product/Product.aspx?Item=N82E16820145345 So I should be good on that. The monitor, well...TV is a 40" LED SHARP AQUOS Quattron at 1080P.
I am somewhat interested in 3D.....so how is AMD on 3D or what is required ? Also I have the same question concerning Nvidia 3D.
Like I said, I was initially looking at GTX660/HD7870 tier cards. Am I looking at the right performance level ? Or would something more just cause the 8120 to be a bottleneck ? I can spend exactly $300 on a GPU.
My favorite GPU brands are....EVGA and ASUS. I have only had those before, and a XFX card. All other companies, really dont know anything about.
Thanks for any help....:ninja:
EDIT: I will be buying the GPU this week in Rockville MD at Microcenter. But if there is a better deal at like Newegg, I have no problem ordering from there.
