Need advice: Inventory Management System
Uconn411
152
I am looking for a fairly large scale inventory control system to keep track of computers and their peripherals in various office buildings. The type/model of the component should be noted, and such things as O/S, and programs installed might also need to be jotted down. The main purpose is to find out what equipment is in what room, and track it when it gets moved to a different room/user. Anything from using PDAs to barcode scanners are a possibility. Thanx for any advice.
EagleKeeper
Discussion Club Moderator<br>Elite Member
Staff member
Oct 30, 2000
42,589
Most Manufactures that sell Bar Code equipment will have recommendations on S/W which supports their stuff. It may be their own or a third party S/W package.
Depending on scale and network access, a simple database with human entry may suffice. You could print out your own codes and have the human enter the id code when equipment is relocated.
