Ok here is the deal, I just rented an apartment that is probably 40-50 yrs old. The problem is that it does not seem to want to cool. I bought a new digital thermostat and the A/C runs 24 hrs a day and will not get below 80 degrees. It is also weird in the fact that the temp on the thermostat flucuates wildly. 1 minute it will say 83 then I will turn it off and it will go down to 79 or even up to 85, this is when the A/C has been running for 4-5 hours nonstop. I have weatherstripped all the windows and even around the attic door. Tommorow I am going to put a piece of plywood over the fireplace opening. The landlord came over today and said the thermostat was off by 3 1/2 degrees when it said it was 82 in here it was actually 78. The other problem is that when the thermostat says its say 82 and I set it to 82 it still runs all the time and wont shut off, it will only shut off if I set it to a degree higher than it is reading. I know this isnt a thermostat problem b/c I installed the same exact one in my other apartment and it shut off as soon as the temp got to the reading that I had set it at. My landlord doesnt seem to think there is a problem when I told him it ran all the time, he said "Yeah people complained about that, but because it is so humid out its gonna do that". I dont see how that is possible conisdering it just rained here and it is about 4-5 degrees cooler outside the place than it is inside and the damn A/C has been running for the past 2 hours. Someone PLEASE help.
