I'm planning on upgrading my two year old build very soon. Gaming performance is the primary concern and getting the best product for the money at the price range I'm shopping at(mentioned below for each part). I'm not a fanboy of any brands and I don't plan on doing any overclocking. All parts will be purchased in the USA. I will be using this new build for the next two years before upgrading again.
For the most part, I plan on keeping my old monitor, case, sound card, keyboard, mouse, HD, optical drives, and PSU. I know very little about PSUs though and I'm not sure if it would support the latest video cards and CPUs, so any input is welcome. My current PSU is an Antec 430W TP430... Here is a link with the specs. It has supported my current build without issue(7900GT, A64 3800+, 1HD, 2 optical drives, 3 case fans). I would like to save money and continue using the same PSU, but only if it won't compromise the stability of my new build.
I only have a vague idea of what my next build might include right now. I should also say I'm not very knowledgeable about the latest hardware performance specs, as I only tend to research hardware when I want to upgrade. Anyway, here's what I'm looking at right now, any suggestions are welcome:
-CPU: My price range is from $200-300. Perhaps the core 2 quad q6600 or the core 2 duo e8400? Any thoughts on quad core vs. dual core? Other processors to consider at this price range?
-Motherboard: I would prefer to pay less than $100 if possible. No idea what's popular lately. I don't need any fancy overclocking features, just a reliable and affordable chipset. I also wont be needing onboard sound or video.
-Video Card: Price range is $200-300. After the small amount of research I've done, I was thinking about an Nvidia 8800GTS . Any other cards I should consider at this price range? I should also mention that I only use a 17 inch monitor at 1024x768 for gaming. I'm happy as long as I can play the latest games at this resolution with mostly high settings for the next two years.
-Memory: I would prefer to pay less than $100 if possible. I'm thinking 4GB would be ideal for the new gaming build. What speed/type of memory should I get? Aren't you supposed to match the CPU FSB with the memory speed/type? And since I'm not overclocking, should I pay much attention to the various timings or voltages when purchasing? Any reason to buy DDR3, or should I go with DDR2?
-Operating System: My current system is using Windows XP, but I also have a 32 bit copy of Windows Vista Home Premium. I would like to use Vista on the new build... but should I buy the 64 bit version instead to go with the new CPU? Is this really necessary or useful... particularly with respect to gaming performance? I would like to save money and use the 32 bit version if possible, but not if it will really slow my system down. Also, how much HD space does a typical Vista install take up? And is it more difficult... or easier to setup/install than XP? I mean, are there any notable differences regarding the installation process I should be aware of?
