Need advice for HDCP video card for HTPC...
Jagercola
384
I've got an ATI x800 currently in PCI-E, but I need a card with HDCP to show off my HD_DVDs off digitally. HDMI is a plus, but not required. Since it is for an htpc, a queit card is a plus, but a low price is the deciding factor. Thanks for your input and recomendations.
Jagercola
384
Oohhh thanks for the info. Are you sure it does HDCP? Some sites list it and other sites don't as having it.
The price is right though!
keeleysam
8,131
Yes, it supports HDCP.
thilan, do you honestly think that a 7 series card does not support 1920x1080? It'll work up to 2048x1536 with zero issues.
