eggrolls
I want to reduce the temps on my Q6600. It's currently ~50C idle and ~65C full load. My setup is as follows:
B3 Q6600
AC Freezer 7 Pro (fan next to mobo heatsink, air blown up toward PSU)
Asus P5N-E SLI
Antec TP Trio 550W
Old Lian Li case (similar to this one, except with 1 80mm exhaust)
The reason the Freezer 7 is blowing upwards is because I can't mount it with air blowing toward the rear 80mm fan without trimming the plastic on the fan. Would blowing toward the 80mm exhaust fan instead of the PSU make a noticeable different in temperature? Also, would some sharp scissors or knife be enough to trim the plastic?
I also want to reseat the northbridge heatsink and install one on the southbridge. Would lens cloth and rubbing alcohol work for cleaning? Also, should I use my 1 year old AS5 (unopened, stored in a cool place), or buy some new AS5 or MX-2 paste?
Thanks!
B3 Q6600
Asus P5N-E SLI
Antec TP Trio 550W
Thanks!
