elconejito
You guys have always been good to me whenever I've needed some advice on parts, so I'm back again. I haven't kept up much with recent news and upcoming product launches, so over the last few days I've been shuffling through the boards here and I think I know enough to get in trouble, so here goes....
I'm currently running a Q9650 at 4Ghz w/8GB RAM, 2 sets of WD 640GB drives in RAID0 as a boot drive and scratch drive, and a WD 1TB and 1.5TB as storage. This works great for most of the stuff I do.
The improvement I'm looking for is in video encoding speed, and also lowering power consumption/heat when I'm just surfing the web (don't need 4Ghz for that).
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
A mix of a lot of things.
-The most intensive will be video encoding (the more threads the merrier) primarily using Handbrake to x264, but some other encoders as well.
-Some VMs. Nothing really heavy duty but often enough where I want good support for it
-Adobe Photoshop, Illustrator, Dreamweaver, InDesign. Also Premiere Elements (not the Pro version) for light video editing. Basically graphic design, web design
-coding/development - mainly web right now but I will soom be experimenting with some android development
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
Max $1000 but the lower the better.
3. What country YOU will be buying YOUR parts from.
USA. Newegg and Amazon mostly
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
Not really.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
PSU (corsair 650), case (antec 1200), GPU (ATI 5770), HDDs, DVDRW, monitors, keyboard, mouse, speakers
6. IF YOU have searched and/or read similar threads.
Yes. I have a decent idea of what I want/need
7. IF YOU plan on overclocking or run the system at default speeds.
Light overclock. I want to keep the turbo-ability, meaning it only clocks up when needed. If I overclock can I still keep turbo? I assume so but just checking...
8. What resolution YOU plan on gaming with.
1680x1050
9. WHEN do you plan to build it?
Ideally mid August
10. Don't ask for a build configuration critique or rating if you are thin skinned.
Goes without saying... I'm looking for advice here.
PARTS:
CPU/Mobo
CPU = Intel i7 2600k - Picked
MOBO = GIGABYTE GA-Z68X-UD4-B3 - Contender
I've been eyeballing the i7 2600K and a Z68 mobo (don't know which to get). I like the fact that it will run at a lower clock and turbo (OC) by itself when needed instead of constantly running at 4Ghz. I would like to squeeze out a little more performance (because I can 😀 ) by lightly overclocking. I should be able to do this and still keep a big separation between "normal" clock speed and "turbo" clock speed right? I don't know what types of speeds to expect here though.
I'm guessing it's not going to be worth the wait for the 6-8core SB-E CPUs? However IB CPUs may be out this time next year if there is something I might want to upgrade to that will still work in this mobo correct?
CPU Cooling
Cooler = Prolimatech Megahalems - already bought, likely re-use
Cooler = Corsair H100 - looking into it further....
I'm currently running a Megahalems, but I'm thinking I want to try a closed loop water setup. The Corsair H80 is out now and the H100 might be out by the time I'm ready to place the order. Thoughts?
RAM - Lots of it. The few Z68 boards I looked at supported up to 32GB so I'm thinking 16GB is a no-brainer and I'll see if 24 or 32 is feasible in the budget. I'm a little partial to G.Skill and I read an article somewhere that DDR3 1600 was a good fit. True?
SSD Lots of contenders - Seems like Intel 320/510, Crucial M4 and Corsair Performance 3 are in the mix for somewhere around 120GB of space (I'm currently using 100GB on my OS drive, not sure if I can prune that down a bit). Any advice here?
Video
ATI 5770 - Keeping it.
I'm currently running an ATI 5770. Not sure if it would be worth it to upgrade? I don't game much but when i do I like to turn up eye-candy as much as possible. However I do need to balance that with having a low-idle power consumption since I don't use it much. My monitor is 1680x1050. If I did upgrade this, I'm only looking to spend *maybe* $150-ish, but only if it's worth upgrading from the 5770.
Updated 7/28 based on some feedback.
Not really.
1680x1050
Ideally mid August
PARTS:
CPU/Mobo
CPU Cooling
Video
