Need Advice for a building my own system (Specs)
imported_gotchaz
7
For years Dell was my only choice, as this was a low cost option. Now I feel I should build my own system as Dell is not an option anymore. Some criteria's I have:
- Low-Mid Range Cost
- I'm a mild gamer, so graphics doesn't need to be the best (I'd like to add 2 LCDs eventually though)
- I have 6 Hard Drives and probably will get up to 9-10 eventually
- I'm not into too many intensive apps such as photoshop
The main concern is motherboard and cpu. I'd like to have some firewire slots. The choices are overwhelming, not sure if I should be going with AMD or Intel. My case choice is probably a Lian-Li (PC-V2100BplusII). Not sure about the PSU.
Any help along the right direction would be greatly appreciated!
benplaut
229
Here's something to start you off:
CPU: Intel C2D 6300. Best performance for the price
RAM: 2GB cheapie (not overclocking?). Might want to go for 1 1gb stick now, and add another when prices are better
GPU: i'd look for a Nvidia 7600GT, or a 7900GS if you can find one on the cheap
not sure on the rest
imported_gotchaz
7
Thanks to both Pkme2 and Benplaut.
yeah it seems like most people are recommending the C2D 6300. I guess since I'm on a budget 1 GB will be decent for now since I can always buy one later.
