Need Advice For A 80MM Case Fan?
afropuff
Hello all,
I was wanting to recieve some recommendations on a good Case fan for my Chieftec case (basically an Antec)...it needs to be one of the bigger fans (I think is 80mm?? Not sure, might be slots for a 120mm, can someone verify?). The 2 x 80mm fans that came w/the case when I bought it are pretty quiet. I was wanting to know which case fan you all would suggest to put in the front of the Case, to blow air to the rear? I don't care about color, just something cheap, moderately quiet and good..
thanks for any opinions and info!!
-EB
p.s. here is pics of my case for reference (http://www.newegg.com/app/Showimage...64-10.JPG/11-125-264-11.JPG/11-125-264-13.JPG)
80mm
panaflo L1As are quiet, you prolly wont hear them even. hit the hot deals forum and search for panaflo, someone found them for about 3 and change per fan, which is VERY cheap for these, quality fans, and quiet, theyll do perfect.
go with panaflo, best quiet fans ever and they performe too
AMD Athlon XP T-Bred B DLT3C 1700+ @ 2.3GHZ (1.775v) 400FSB = 3200+
Abit NF7-S V.2 (nForce2-U400)
Corsair TwinX XMS 3200LL 512MB @ 2-3-2-6 (2.6v)
Sapphire Radeon 9500 Pro 128MB
Antec TrueBlue 480W
Thermalright SLK-947U with 92mm Vantec Tornado @2800RPM
Maxtor 91531U3 15GB
2x Western Digital WD400BB 40GB serials
Antec PlusView 1000AMG
Cambridge SoundWorks MegaWorks THX 550 5.1
