Need advice: finding headphone replacement foam earpad, mine is broken
jimmyhaha
2,851
Hi, all
I know a lot of u guys use headphone & My headphone foam ear pad crack and wear off
I go to Radioshack today and their ear pad is too small (mine is 2.5")
I am out of idea where I can find replacement ear pad (online or B&M for cheap)
FYI, it's a RCA IR headphone, I can't even find it on RCA.com.. lame RCA
Pls advice
zemel
486
I had the same problem with my headphones for my Sony Walkman...remember those...they're still being made.
After looking around the 'net; I decided it wasn't worth the time and trouble; I found one piece in a drawer, but it was old and stiff and was too difficult to attach.
So I gave up and bought a new headset at Circuit City for about $ 15. I think and they're foldable, too.
Sony's website has plenty of info on the different models; if that's the brand you want. I can't wear the "in the ear" type and don't like the neck wrap type, so I chose the over the head model. YMMV
manly
13,324
4,098
Koss sells inexpensive replacement pads for all their models (I believe).
I even paid $5 shipped for replacements for my cheap KTX Pro headphones ($15ish). Unfortunately, the pads they sent weren't the original OEM pads, which I later discovered are permanently hooked on. I could tear them out, but there's no way to adequately affix the replacement pads. Not to mention they are much inferior to the original pads (in fact they're thinner than my WORN-OUT pads).
I never bitched to Koss about these problems, but needless to say I'll hesitate to buy replacement pads for budget headphones from now on (as an aside, I was quite pleased with the sound of those headphones).
