Hi there..
I really could use some advice with selecting a new case for my next rig.
I have some criteria; It should be spacious, enough to fit a watercooling system with margin
It also should have 120mm fan options rather than 80/90. And oh yeah, i want it to be quite "sturdy" to avoid noise.
Planning on using about 2-3 120mm fans in it (2 exhaust for the dual rad) and perhaps an intake in the front. Dont know about that really just yet.
I have gave Thermaltake Armor some thought, which seems to be perfect. BUT, the 25mm side window fan is not available just yet in Sweden, i guess it's quite recently out in the public. I was almost set on this particular case until i notices it had a fan exaust on the top with plastic surroundings, making it hard to make a nice rectangular hole for the radiator, which i plan on mounting in the top.
I also had a look at the Gigabyte 3D Aurora, which i read a review of. It seemed perfect until i was told that the dual 120mm fan holes in the back couldnt fit a black ice dual rad, which the reviewer stated. So mush for reviews, huh?
So come on poeple, hit me with your best shot.
