redwingslv
I'm building a new system (mostly) Please let me know what you think:
CPU: Athlon64 3400+
MOBO: Option 1--> Abit NF8
Option 2--> DFI LanParty UT nF3 250gb
RAM: Corsair ValueSelect Ram PC3200 (2x512)
HDD: x2 Seagate Barracuda 7200rpm 80GB HDD (RAID 0)
PSU: Antec True Control 550W
DVD Burner: Lite-On 1633S
I will be keeping my existing MSI GeForce4Ti4200 AGP 128MB video card, would like to just use the on-board sound, stock HSF (air cooling only). My intended uses are as follows: importing video from analog video camera thru Ti4200 card, burning video back to DVD, using firewire later for a DV camera I will buy later, and playing some basic games. I would like to option to OC a little (new to OC) but not very much and not really important. I am looking mainly for a nice, stable system (current PC is VIA KT133 chipset w/T-bird 1.333 - many problems thanks to KT133)
Am I correct in understanding that the on-board sound is decent, firewire is included (no other cards I need to buy) and no need to buy a network card? Also have been told stock HSF is adequate for Athlon64 unless major OCing is intended.
Research makes me worried about VIA chipsets (especially past problems) nF3 250gb seems very good.
I may upgrade video card down the road to allow me to play latest games better. I know keeping my Ti4200 limits my game playing for now.
Which board is best for stability? I've read DFI Lanparty UT is one of the best OC boards around for s754. That's not my reason to buy it though. Others have preferred Abit NF8. I have read forum concerns about CPU temp reporting in BIOS w/Abit NF8 but heard new BIOS update should be out in mid Feb 05 to fix it. Won't be buying until after then anyway.
Any thoughts on this would be great. Budget is under $1000 (and I need a new case too.) Main concern is stability!! Which board is best bet for stability and good support?
Thanks.
CPU: Athlon64 3400+
Thanks.
