- Jun 19, 2015
- 3
- 0
- 0
Hello everyone,
As the title states, I require your advice in compiling specs for a powerful gaming PC. Now, my experience with building PCs is minimal at best: the most I've done in the past is pick out certain components (GFX card, sound card) and I've trusted a local vendor to pick out the rest of the components. Planning to do something similar now: there's a local retailer who is known for building really good gaming systems, and I will be relying on them, as well as sourcing most components from them. However, I'd like to be well informed about what sort of specs I should be looking for, and so I come to you for your advice.
To start with, I've picked out the video card I'd like to build the system around. Based on my budget (and whatever I've picked up from reading articles about current GPUs), I'd like to build a PC around either the nVidia Geforce GTX 980 TI, or the soon to be released AMD Radeon R9 Fury X. Is this a good place to start when building a PC?
Anyway, I've tried to answer the build questions to the best of my ability below:
Gaming, mostly. Some Photoshop and Illustrator here and there (for brochure work, digital painting, etc.), and the occasional movie.
But I hasten to add: I'd like the build to be as cheap as possible! I don't need a fancy case (just something with decent cooling), and I don't need a sound card (I'll be using a USB Creative sound card), blu-ray drives, massive SSD, etc. I'm perfectly happy with an ordinary looking CPU case, a 120GB SSD, etc. I'd much rather that the internals were very capable, and even here, with my budget, I understand that compromises will be required.
India.
Most parts will be sourced primarily from Golchait Computers. They've got a fairly large catalogue of products available (from what I can tell, anyway). I can also access the following online retailers:
Amazon India
Flipkart
Snapdeal
There are a few more local stores I can access, that don't have websites/online catalogues, but they too have a fairly good selection of stuff available.
Nothing.
With the GPU, I'm happy with either nVidia or ATI. No other specific preference.
Sound card: Creative Sound Blaster XFI HD sound card
Keyboard and Mouse
Default speeds.
1440p QHD resolution (preferable).
September of this year.
Windows.
Nothing else.
I hope that answers everything.
Thanks in advance
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Rs. 120,000 - 150,000 (which amounts to $2350, according to xe.com)2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
3. What country YOU will be buying YOUR parts from.
India.
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from.
We can't be expected to scour the internet on your behalf, chasing down deals in your specific country... Again, help us, help YOU.
Amazon India
Flipkart
Snapdeal
5. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
Nothing.
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
Keyboard and Mouse
7. IF YOU plan on overclocking or run the system at default speeds.
Default speeds.
8. What resolution, not monitor size, will you be using?
9. WHEN do you plan to build it?
Note that it is usually not cost or time effective to choose your build more than a month before you actually plan to be using it.
10. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
Windows.
Nothing else.
Thanks in advance
