shaaregeulah
Hi all. I have a Dell Dimension 4550 (P4 3.06gHz/2GB DDR.) The specs are listed here I use the system for Pro Audio production and, unfortunately, I've been using it for personal home use as well. I've decided to get two additional hard drives and install a seperate operating system on one of them, dump all the audio files to that drive as well and have all the programs and plug-ins on the other hard drive. This way, I can use the same system for personal use and production without conflicts. I've learned that having the operating system and audio files on one hard drive and the programs and plug-ins that need to be running on another hard drive is best for optimal performance. So in total I'll have three hard drives:
1)Personal use(with OS)
2)Audio Production and files(with OS)
3)Programs & Plug-ins(slave to #2)
The problem is my system only supports 2 IDE hard drives, as you can see in the specs at the above link. I realize I can use an IDE controller card, but I've heard that I can have issues with that. Also I'm not sure if it's best to have the third hard drive just resting on the bottom of the PC's case as there are only two slots for drives in my case.
So to sum up:
1)Do you recommend an IDE controller card?
2)Do I get a new motherboard?
3)Any other solutions?
Also, my current power supply is only 250 watts. I have 2 CD drives and 3 PCI cards installed, so with 3 total hard drives, should I get a more powerful power supply? If so, how powerful?
I'm going to be starting a new project next week, so I really need to do this fast. I appreciate your advice. Thanks in advance.
So to sum up:
