need a wireless router
danzigrules
I need a router that can allow certain pc's on my lan access to only certain sites.
My old netgear mr814 had this option, but it seems that all the routers I buy only have the option to block certain sites.
Does anyone out there know of a wireless G router that allows what I want?
Thanks
The D-Link DGL-4300 can do this.
The Linksys WRT54G with 3rd-party firmware such as DD-WRT really ought to be able to do this, but it doesn't as far as I see. It has fairly flexible blocking policies, but no white-list capabilities (that I saw). Perhaps this is so because it's fairly difficult in general to maintain white lists, as they get very large for most people. If you're really inclined, you might be able to add this capability yourself (or have it added), and perhaps some other 3rd-party firmware has done exactly that.
