need a webcam solution (different rooms)
rh71
52,844
1,049
Want to webcam the kids in their crib in a room different than where I keep the PC. Already have a decent usb webcam but obviously it's 6ft max. I'll want to stream that out too (which I used to do many years ago with webcam32). What is the best solution these days? Surely there've been advances in this department? I do have wireless as well as a ethernet lan drop near them.
nboy22
3,304
Check this out
Here
Ethernet over power lines could make it easier to hook up a camera.
Also you can search for Wifi Webcamse.
Like this
rh71
52,844
1,049
thanks but wifi webcams are way out of my price range. I looked up wireless usb hubs and that's $100+ also. I was hoping there's something I didn't think of... some sort of ghetto home solution someone's using. I suppose the only other way is to have a simple 2nd pc out where I want the camera... and I'll need a monitor out there too - all this is just not a good place for it there... too much crap to get a webcam going.
QuixoticOne
1,855
a) get an *analog* video camera, they're often pretty inexpensive. Feed the NTSC video output over coaxial cable over to an inexpensive video capture card in the PC in the next room.
b) get a cheap PC like the $75 Intel ATOM motherboard + CPU (both included) from newegg, stick in one of the $22 sticks of 2GBy RAM and find a $25 case + PSU on sale to stick it in. Use a normal USB webcam with that. Advantage: you can have a quiet cool running PC on 24/7/365, and it'll probably save you money over the months in electricity bills anyway. Added bonus -- if you run one of the LINUX based webcam surveillance programs on it it'll more easily do things like motion detection and enable easy remote access for your review if you're out of the house like a webcam-over-the-web or sending snaps to your cell phone / via email or whatever. Consider if doing continuous webcam capture will interfere with your use of your normal PC, what the energy use cost of leaving it running will be, whether it will likely crash often in this capacity, whether good free capture / video processing software is available freely which will meet your needs for it, et. al.
c) get one of those wireless RF modulators and a camera that outputs NTSC video and then you can send the signal wirelessly to the next room, though coaxial cable would be better.
d) USB cables can be daisy chained through multiple hubs. MAYBE if you got 2-3 cheap AC powered USB hubs and some 15' or however long is reliably available USB cables you could get the string of them to be long enough to put a USB webcam into the next room. Potential problems with data corruption / flaky operation / electrostatic discharge / tripping over the cables exist.
