Need a tv tuner without a pc to hookup my monitor.
50
I need a tv tuner (I'd like to keep it relatively cheap) that has vga output. I can't connect it to a computer so I need it all to come out of one box. It must have a remote. Any suggestions? Thanks
How well do those VGA converers work? I've heard some bad things about some of them
BTW I am planning on using Antenna and maybe I'll route a wire for cable(analog) later.
What kind of monitor do you have?
It might be cheaper to just get a regular tv than go through all this.
Yeah find a used 27" or so TV for $100 or less. If you gotta spend $50 or so to use your monitor may as well get the TV.
I watch cable through my monitor cause it came with the input, and a VCR is easily found... well had to pick up $10 worth of cables, and could use another $10 still.
It's a crappy old lcd (probably worth about 100 or less). It's going to go in the kitchen and I want to save space. I'm not planing on using it as my main tv.
