Need a system cooler
Bateluer
I need a cooling device that resides in a 5.25in bay that intakes air. I haven't been able to find anything that I am 100% cetain performs that task.
Anyone know anything I should be looking at?
Originally posted by: KoolDrew
What is it going to be used for?
Bringingin air from outside the front of my case inside the case. I think the front bezel is limiting the air intake of two 80mm fans near the bottom. But, running without the bezel makes the case look ugly.
So I need an additional intake.
Originally posted by: suszterpatt
I'd just get faster fans if I were you. Those drive bay things don't move much air anyway.
I beg to DIFFER if these specs are right!
I've never seen one in use or know if those specs are right, but if they are, I need to get a few of those myself. I think that's what you're looking for though.
Looks like a hoax. Can't find it on Evercool's website either.
Well the website's not a hoax, I just got some things I ordered from them and the service was great. The product is here on Evercool's site. Specs are the same there too.
Those specs still look outlandish, though it's quite an original design and frankly, I have no idea if what they claim is believable. You're on your own on that one, but do report back. 🙂
I saw those a while back, wasn't sure how well they worked.
I'm not certain I could install 120mm fans in the bottom front of my current case, not to mention, I would have to remove a drive bay with two SATA drives in it to get at the front.
I might try the Evercool, see what it does.
