- Jan 2, 2006
- 10,455
- 35
- 91
So I made a thread a while back about wiring a 400W inverter and running my laptop and subwoofer off of it. It's hooked directly to the car battery but it's mounted in the trunk connected with 12 gauge wire.
Long term report:
I think the voltage drop due to the thin wire is severely affected the reliability of the inverter. Even when driving the inverter will turn on and off and the subwoofer will turn off frequently. The low voltage alarm of the inverter is always on, and when I'm parked it sometimes has trouble just staying on powering just the laptop.
So I want to replace the wire with 8 gauge, but I need a switch in the cabin so I can turn the inverter that's in the trunk on and off.
How do I get a switch that can handle being hooked to an 8 gauge wire?
Long term report:
