Need a suggestion for modding my system.
SirChadwick
4,595
I don't want the wires to show everywhere. Isn't there something you can buy to cover them up or run them through to make it look neat? Where can I get this at a good price?
zoiks
11,787
you can use ties to tie up the cables and then use hose tubing to make everything neat.
HappyPuppy
16,997
Put the side panel on your computer. Nobody gives a flying fvck what the wiring inside looks like.
SirChadwick
4,595
Thanks Zoiks. At least someone around here gives an answer worth reading.
minendo
35,560
22
What is so wrong with wrapping the cables with electrical tape? Much cheaper than tubing and you can even buy colored electrical tape for ~$0.97 a roll.
SirChadwick
4,595
Well considering that I have all of my wires wrapped in electrical tape right now and my computer looks pretty ghetto'd out.... I think I need something a little nicer. I've seen other systems with some typeof tubing around the wiring and it looked quite nice.
