Rob_63
My current board is an Intel D945PVS which has Intel Hi Def. SigmaTel audio chip, it has a front breakout box and does what I need it to. But, have decided to go AMD dual core and will be probably getting an Asus board.
What I need it to do is input from a set of electronic drums, and be able to play over / mix a media player. My current setup does this, but it is time to move on from it.
I am not a heavy / serious gamer, I do a little now and then so it is not of ultimate priority, what is important is good sound quality and being able to do the mixing from an input. I have a set of EV Sonic 2.1's that I will not part with, they retired my Klipsch promedias to my daughters rig.
Can any of you guys that are musicians out there recommend something that will achieve my goal for under 200?
Thanks!
Thanks!
