HeXploiT Diamond Member Jun 11, 2004 4,359 1 76 Jun 5, 2010 #1 Need some help finding a single slot gaming card for < $100. Must support DX10 at the least. It's going into an XPC.
f4phantom2500 Platinum Member Dec 3, 2006 2,284 1 0 Jun 5, 2010 #2 Radeon 4850 sounds like a pretty good choice.
taltamir Lifer Mar 21, 2004 13,576 6 76 Jun 5, 2010 #3 your options are extremely limited with single slotters and the price range you gave... The closest I found are: http://www.newegg.com/Product/Produc...-354-_-Product or http://www.newegg.com/Product/Produc...-448-_-Product for a 5750... for a little more you can get a 5770 but its already slightly over budget.
Leyawiin Diamond Member Nov 11, 2008 3,204 52 91 Jun 5, 2010 #4 http://www.newegg.com/Product/Produc...82E16814121376 HD 4870 1GB (yes). Pretty cheap too (even thought its over you budget). If you must stay on budget, HD 4850 or HD 5670 for ATI, maybe 9800 GT for Nvidia. http://www.newegg.com/Product/Produc...82E16814121352 If ASUS follows through with their rebates that would actually be a decent deal. Last edited: Jun 5, 2010
