Need a Silent HSF for A64
Gundam
What would be a good HSF combo for an AMD64 cpu? I'm not going to be overclocking, so I don't anything extreme. Just something affordable, and siginificantly better then the stock unit.
I second the Zalman (I would go with the all copper version CNPS7000-Cu). You can get the non-A version also and it will cost you less,....if you are on a budget. Look for the CNPS7000-Cu @ eWiz for $33. About 40 right now for the CNPS7000A-Cu....and its only a revision, no actual major difference.
