Need a really quiet 120mm fan.
Ricemarine
10,507
Antec TriCool 120mm, the one with the 4 speeds, put it at lowest. If you can find one...
My 2nd suggestion would be the 120mm nexus real silent fan.
They pull air, while being silent.
SilentX is not liked on the silentpcreview forums because they can't pull that much air with that little noise.
ribbon13
9,343
Originally posted by: xbassman
The other fan isn't a Yate Loon.... ("compare to Yate Loon/Nexus")
Actually I bought one, and the frame is most definately molded plastic done by a Yate Loon mold on a Nan Shu NS-450T. There is no question that Yate-Loon manufactured it.
All you need to know is here
xbassman
1,243
Well, I thought I was about to be corrected, but this is a quote from the link you provided:
Notes
It appears that this fan may share some components with the Yate Loon fans. The fan blades have a more curved edge than our Yate Loon samples, but the blade is similar to a Nexus fan I have (re-branded Yate Loon D12SL-12). Additionally, other sources report Yate Loon fans with these curved-edge blades. The frame has some similarities with our Yate Loon fans ? most notably the dimples near the mounting holes. The motor appears to be sleeve bearing, which all our Yate Loon fans use. My guess is that this fan and similar Yate Loon fans are sourced from the same factory, but with different specifications. Alternatively, they could be assembled in different factories, but sharing some parts (fan blades, frame, etc.).
Despite the similarities with the Yate Loon fans, motor and bearing noise was significantly higher. I attempted lubricating the fan bearing, but results were the same. Vibration is moderate on-axis, and high off-axis, with the fan tilted at 45 degrees. Airflow delivery, while abundant, is not smooth, and varies depending which way the fan is turned. Though our SLM measured only a small difference in noise between the D12SM-12 and this fan, the quality of the noise was worse. It is the noisiest fan of the group.
The reviewer only speculates about the actual manufacturer.
Of course, this doesn't mean that it may not be a good fan, but the one sample used by this reviewer was determined to be of lower quality than the Yate Loon samples.
