need a really long ethernet cable
ShadowBlade
4,263
might need up to 320ft...300ft min
i obviously cant buy one that long, so do spools come that big?
ScottMac
Moderator<br>Networking<br>Elite member
Mar 19, 2001
5,471
Spools are common at 1000 feet. Occasionally you can find one that's 500.
Good Luck
Scott
Mokmo418
339
get a roll in a box and make your own... or have it made
for less than 100$ you can get a kit with a crimper and 500' of cat 5 cable (given the distance, might make it some cat5e)
skyking
22,711
5,839
get a roll of 5E solid and terminate it in keystone jacks, mounted in surface mount boxes. Then use standard patch cables to hook up the devices.
helpme
3,090
Remember when using CAT5, the max distance is 100m (about 330ft). If you use CAT5e I think it goes up to 300meters?
SUISIDE
78
make sure you wire it like this:
pin out. pins 1-8 = left to right
1: white/green
2: green
3: white/orange
4: blue
5: white/blue
6: orange
7: white/brown
8: brown
if you need a x-connect cable switch pins 1 and 2 with 3 and 6 on one end of the cable.
ShadowBlade
4,263
where would i get one of these?
the only thing i can find at radio shack is a 100ft roll
Carazariah
336
Online
http://www.cablemakers.com/network_cable.htm
I hear that Home Depot and Lowes carry large spools of network cable but their website search engines are not functioning to find either Network cable, Cat5 cable, nor patch cable, so I have no idea what they call it but I've heard they carry it.
Thanks,
C
spidey07
65,469
I'd really recommend against making your own cables and just just two keystone jacks. You don't even need to put them in a plate.
easy, cheap and reliable. There's just too many things that can and normally will go wrong with homemade patch cables.
JackMDS
29,546
422
And if you do not know hoa to follow this good advice click here: Wiring - I would like to wire my Networked Computers (Home Wiring).
:sun:
spidey07
65,469
:sun:
thanks Jack. Your links are extremely helpful.
Schwagoo
12
Oh C'mon... making your own cable is NOT rocket science. anyone that has the tools and can search Google for instructions can handle it.
The first few tries take some patience. After that is as easy as wiping your butt.
spidey07
65,469
Yes, but when the cable is scanned for CAT5/5e/6 specs it rarely passes. Without proper access to a scanner one can never really be sure.
Also, somebody does indeed need to correct wikopedia. Cat5 spec is for 90 meters of horizontal cable, with 5 meters of patch cords on each end.
skyking
22,711
5,839
They have not spent hours troubleshooting a bad crimp job that works just enough to throw you off. Solid 5e and two keystones will set you back about 75$, and premade patches are a buck apiece. What is your time worth troubleshooting a bad crimp job that is 300 feet away?
I think whoever put that wikipeia entry in got confused about 100mhz vs. 350 mhz, and put that in as meters. cat 5e is not rated at 350 mhz, but many patch cable suppliers will tell you they tested to 350 mhz.
If you could run cat5E at 100 base T for 350 meters, we'd have been doing that instead of fiber;)
http://cablingdb.com/Standards/568B/TIA-EIA-568-B1.asp
ScottMac
Mar 19, 2001
5,471
I'd vote for 5e solid with keystones at each end as well. The chances of screweing up are much less.
For the average home networker, you can flub a crimp and (maybe or maybe not) be successful. Most home networkers are not making runs that are close to the max length.
For a cable that long, if you flub a crimp (or any of the other specs) and it's gonna work like crap (if at all).
Wikipedia needs to be corrected ... besides, who in their right mind would try to pull definitive, accurate information from a place called "wikipedia?" C'mon. If you want cabling spes, go to the TIA/EIA .... the folks that maintain the spec, or (at the Least) Anixter's site (www.anixter.com) which has a tech library.
Anixter wrote the spec that was eventually downgraded (by committee) to become the "Catagory" spec.
True enough, the mechanics of crimping on a mod plug are trivial ... but doing it according to spec, following the rules, takes a little education, practice, and dexterity (and a good pair of US$50.00 + crimpers).
As long as the OP keeps less than a 1/2" of exposed wires, maintains a 4" bend radius, and uses like-rated (5e) keystones ... the chances of success (success = properly working cable @ rated performance) are much greater.
FWIW
Scott
nweaver
6,813
they hardest part about making your own is keeping the twists in the twisted pair until right before the jack. You don't get much room for error with 5e. Keystone jacks are MUCH easier to terminate with, and come with their own tool (no need to buy a crimper).
imported_rod
1,788
I made my own cable, and it works fine. It's using about 25meters of cat5 cable, with an RJ45 plug at each end. I just borrowed a cat5 crimping tool off a friend who used to work in a computer shop. If you really want to be sure, Cat6 will do that distance easily. Cat5e should also manage it okay, although i wouldn't use standard cat5 at that length.
Just buy yourself a length of cable and a few RJ45 (8p8c) end plugs from an electronics store, and buy/borrow/steal a crimping tool from somewhere.
RoD
mparr1708
258
RoD
This is incorrect. If you want to go over 100 meters you need to go fiber...plain and simple. Theres a reason why most big coporations use it. It cost a heck of a lot more but its the best way to get long runs to be stable. Just so you don't have to take my word for it I did a quick google and came up with the following info...
Specifications for Cat3, Cat4, Cat5, Cat5e, Cat6, and Cat7 Cables
Category
Type
Spectral B/W
Length
LAN Applications
Notes
Cat3
UTP
16 MHz
100m
10Base-T, 4Mbps
Now mainly for telephone cables
Cat4
UTP
20 MHz
100m
16Mbps
Rarely seen
Cat5
UTP
100MHz
100m
100Base-Tx,ATM, CDDI
Common for current LANs
Cat5e
UTP
100MHz
100m
1000Base-T
Cat6
UTP
250MHz
100m
Emerging
Cat7
ScTP
600MHz
100m
syco83
62
Originally posted by: skyking
Originally posted by: syco83
does anyone use CAT5E instead of CAT5e?
ROFL!
what is so funny. They are two different cables
big E means it meets the EIA/TIA 568A/B standard
little e does not confirm to the standard but does have the rated frequency and speed.
