Need a quiet 350W power supply for 1.4GHz system
jagr10
1,995
I am building a system with a 1.4 GHz cpu and need an extremely quiet power supply for my Fong Kai case (FK-320). The 300W PS that came with the case is too noisy! I've heard that the Enermax Whisper is quiet. Is that true and do you recommend that for my case and system or is there a better one?
Also, which fan do i need to get to put in the front of the FOng Kai - 320 case? It has a slot for a fan, but i don't know what fits there. Any recommendations would be appreciated. thanks!
damocles
The Enermax whisper is a great PSu and pretty quiet.
I think the FK can mount a 90mm or 120mm fan up front. Wiser heads will offer better advice, but i like the Panaflo quiet fans
damocles
Just checked the spec, apparently the case will hold a 92mm or 120mm fan in the front of the case
stultus
1,774
The Whisper is not extremely quiet. It only is if you're using it in a system with a lot of fans that overpower it anyhow. If you want "extremely quiet" you should go with one from quietpc.com or the Silencer line from PCpowerandcooling.com.
jagr10
1,995
Ok, the enermax whisper fan doesn't say anything about the AMD athlon. IT just says "Meet AMD K7 and Intel 2.03 Version".
If it doesn't say it meets the Athlon then should i stay away from it?
stultus
1,774
No, it'll handle Athlons just fine. But it's not super-extremely-quiet, if that's what you need.
