cleverhandle
2.6.17 changed some tcp window scaling options, causing problems with certain routers and firewalls, notably OpenBSD ones (like mine). But from what I can see, my firewall is set up correctly. So could someone running 2.6.17 check the following sites for connectivity?
http://cvs.horde.org
http://www.everymac.com
Also, if you could do a...
cat /proc/sys/net/ipv4/tcp_window_scaling
...and say whether that's a 1 or a 0.
That would tell me whether the problem is with me or with another router on the Internet.
Thanks.
Thanks.
