Need a PSU for 560ti sli
Suikoden
7
Looking to spend less then 100 for the power supply. Cpu is going to be an I5 2500k. Hate rebates. Any ideas??
dualsmp
1,627
45
Edit: scratch that I misread.
Anyways with a sandybridge it's going to be less than an OC i7. He should be ok with overclocking everything though, processor + two 560ti's
Suikoden
7
Going to have 2 SSD drives and 1 hard drive, I may need more power then. Maybe a 750??
dualsmp
1,627
45
SSD's use maybe 5w each max. Figure 10w for 1 hard drive. You can go 750w if you feel everything you have is going to be OC.
dma0991
2,723
You do not need an additional 100W just to support 2 HDD and a single SSD. HDD does not take a lot of power at all and SSD would need a lot less power than a HDD would. If you want a bigger PSU anyways, 700W is sufficient.
