Need a power supply recommendation
jei3
15
Im looking into purchasing a new system in the next couple weeks and have decided on most of the parts, but I still haven't decided on a good Power supply..
Currently Im looking to pick up..
Thermaltake Soprano
C2D E6600
Asus P5N-E SLI
2GB Crucial DDR2 800
160GB Western Digital HDD
Sony DVDRW
EVGA 8800GTS 320MB
the only power supply that I was considering is the Rosewill RT550-135-BK 550W, only because its cheap and I've had good luck with my rosewill case/psu for the last few years.. I'm looking to stay around $60- $100 for a decent PSU. Any recommendations are appreciated..
Also I'm not planning on overclocking anytime soon if at all, but I would like to have the option of going SLI down the road..
Thanks!
jhurst
663
Every build I have ever done I have done with Enermax. They make some of the best PSU's around....I spent under $100 on my modular 620W Enermax Liberty.
thecoolnessrune
9,673
583
Once again, you are a perfect candidate for the Enhance 5150GH 500W PSU.. This thing might as well be stickied. This PSU is all 98% of computer owners need and has the best bang for buck of any PSU currently out there.
Kromis
5,214
And where can you find one of these?
Butterbean
Banned
Oct 12, 2006
918
I like my Seasonic listed in my sig. I can't even tell its on its so quiet. Efficiency is in the high 80's. Seasonic makes Corsair and PC Power and Cooling PSU's.
thecoolnessrune
9,673
583
E-wiz was the main and cheapest carrier of the PSU and my first pick, but they don't have any in stock it seems. Might be worth giving them a call about it though if you are interested.
jei3
15
Thanks for all the recommendations! I'm gonna check all these out and order in a few days..
Thanks again.
CalvinHobbes
3,524
Buy.com had the Corsair 520W onsale for around $79 after rebate. It's a nice PSU with modular cables.
thecoolnessrune
9,673
583
$79? Might wanna go with that OP. The Enhance is about $75 without rebate but the Corsair is a genuine rebadged Seasonic. However, if you are the type who avoids rebates like the plague (me :p) then I would go for the Enhance. Both will give you excellent power delivery and Quad Core and/or SLI in the future.
Zardnok
670
Definitely go with the Corsair, even if you have to spend a little more than your $100 budget. PSU is most important part of your machine.
Henny
674
I really like the Fortron Blue Storms. FSP has been building quality power supplies for a long time and produce some of the best units out there.
jei3
15
I've decided to go with the Corsair! $105 from zipzoomfly is the best price I've found so far with free shipping, so I'll be ordering tomorrow. Thanks again for all the help.
