Need a New Gaming system
razaghoul
this is the system i am thinking about buying . I PLEASE need to input on this system does anyone have any suggestions (things i should change or upgrade)
i do not plan to overclock but i want a good gaming system that will last a while . i have some money saved up so i can spend around $3500 Can
-AMD Athlon 64 X2 4800+ w/ 2x1MB Cache
- Asus A8N32-SLI Deluxe w/ DualDDR400, 7.1 Audio, Dual GB Lan, Dual PCI-E x16 SLI, Cool-Pipe
- Corsair 2048MB TwinX PC3200 CAS 2 Dual Channel Kit (2 x 1024MB)
- NZXT Lexa Classic Series Aluminum Chassis
-Enermax 535W EG565P-VE All In One ATX 12V v2.0 Limited Quantities
-Panasonic 1.44MB Floppy Drive, Black
-Western Digital 250GB Caviar SE 7200rpm SATA II w/ 8MB Cache
- LG Super Multi DVD Writer 16x16 DVD +/-RW Dual-Layer, Black
- BenQ DQ60 16x16 Dual Layer DVD+/-RW, Black
-eVGA e-GeForce 7800 GT CO 256MB PCI-E w/ Dual DVI, VIVO x2
-Creative Labs Sound Blaster Audigy2 ZS
-Samsung SyncMaster 940B 19in Digital LCD w/ DVI, 8ms, Silver-Black
should i go dual video card or get one good one ati x1900xtx(and if i do what mbo to get)
would i need or should i get any extra cooling with dual video cards ?
do i need a special moniter for dual video cards ?
thanks for any help 😕
cpu: i would change this. your cpu isn't your bottleneck so you should drop down to a 4400+ (saves you almost $200 USD)
ram: get this G.Skill 2x1gig kit or this Corsair Value Ram 2x1gig kit. the ram you put is for overclocking so you don't want that. plus, you save more money buying this ram. the g.skill is CAS 2.5 and the corsair is CAS 3 by the way.
floppy drive: are you sure you need this?
hard drive: get the same thing with 16mb (Western Digital SE16 250GB). only real difference is 8mb more cache
video card: get a single x1900xt (don't get the x1900xtx) and get an epox 9npa+ motherboard. the epox board is over $100 cheaper
Thanks you for the info
-4400 i will get
-ati x1900xt i will get
-motherboard i can get some asus, dfi, gigabyte , msi any models from these any good with a single video card.
-memory how about mushkin, ocz, kingston only other corsair memory i can get (Corsair ValueSelect 1GB PC2-4200 DDR2 SDRAM)
i want to have this up in a couple days so i have some slim pickings 😱
