Need a new cpu fan/heatsink for Socket A
tank45
9
I'm going to switch my 1.4ghz Athlon t bird to another motherboard, a decent fan with thermal pad would be nice. My current when is on a thermal pad and is ages old and riddled with dust...so yeah something half way decent with thermal pad so i dont have to deal with grease.
Thanks in advance
Nov 11, 2004
10,855
Very few heatsinks come with thermal pads, only stock sinks do to my knowledge. Get a tube of Arctic Ceramique and a Zalman 7000Cu. :)
bupkus
3,816
" ...a decent fan with thermal pad would be nice."
What are you saying here?
"My current when is on a thermal pad and is ages old and riddled with dust"
I've used conpressed air to clean many a heat sink. Again, I'm confused.
"...so yeah something half way decent with thermal pad so i dont have to deal with grease."
Kensai has some good advice. The Ceramique is really pretty easy to use compared to others. It's kinda sticky so it adheres to surfaces well and it's non conductive. Note, a little goes a long way.
The Zalman is a bit pricey and also may not fit your board. Link to CNPS7000B-AlCu
However, it will not only fit an AMD 462 socket it will allow you to upgrade later and use it on an AMD socket 754 or 939, or even 940. If you take the above link you will find another link in green letters "Compatible CPUs and Motherboards."
Edit: My bad, that isn't a link.
http://www.svc.com/cnps7000b-alcu-75.html
http://www.svc.com/zalman-cpu.html
http://www2.newegg.com/Product/Product.asp?Item=N82E16835118112
Just a few links to good vendors.
Goodluck.
fuentefan
420
Funny thing about this post. I just installed this on my Thunderbird today. Needless to say it is alot bigger than the stock HSF, but it still fit. I can barely hear the thing running! I bought it from another anandtech'er, but the price on Newegg is pretty good imo....
bupkus
3,816
THERMALTAKE Silent Boost 80mm Ball Cooling Fan - Retail
Compatibility Socket A
ZALMAN CNPS7000B-ALCU 120mm [TYPO, 90mm] 2 Ball Cooling Fan - Retail
Compatibility Socket 478 / A / 754 / 939 / 940
