need a new CPU fan for my AM3 build
robphelan
4,084
17
just put together a nice phenom 955 quad core machine on a gigabyte 770TA mobo.
the stock heatsink fan is way too loud for me.
can someone recommend a nice replacement?
my requirements in order are:
1) as quiet as possible
2) as cool as possible given condition #1
that's it.
Not too concerned with looks or size. I currently don't have any lights & my case is coolermaster scout, so I should have plenty of room
http://www.coolermaster-usa.com/product.php?product_id=2912
Price isn't that big of a deal, but would like to keep at < $50 or so shipped.
robphelan
4,084
17
how about ease of installation? i would really like not having to remove the mobo to install
MisterDonut
920
It's tough to find good coolers without a backplate, but there are options. Honestly, it's worth your time. Are you overclocking? Otherwise you can probably find a cheap replacement (~$20?).
robphelan
4,084
17
actually, i was just thinking and confirmed my suspicions - the case's mobo tray has a cutout behind the cpu allowing easier installation of a backplate.
another thing, I was looking at the Scythe Mugen 2, but I only find AM2 compatibility.. will it work with an AM3?
