Need a new card, r9's what one is better? Please Help.
plzhelpimnew
Hello,
I have been with out a video card for 3 months, stuck using onboard video :( I have been trying to wait for the new r9 3xx series but I dont think I can make it until possibly june at end of q2 for the launch.
With that being said im looking at a video card for around 175 or less and seemed to have narrowed it down to 2.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125679&cm_re=r9_285-_-14-125-679-_-Product - gigabyte r9 285 windforce oc
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150705&cm_re=r9_280-_-14-150-705-_-Product - xfx r9 280 black edition double d
Out of those 2 cards what one is the better choice over all? I have been reading alot of things about both cards and that has only made my choice more convoluted.
I would overclock either card, is the 1gig of ram worth it to go with the 280 over the 285?
Thank you for any help.:)
Flapdrol1337
1,677
93
3GB is an advantage over 2GB in many modern games, can always lower the texture settings of course.
The 285 is much faster when it comes to tessellation, so if a game uses that a lot it'll be faster, and it supports freesync.
I'd recommend the 280 if it was cheaper (which it usually is), but since these have the same price, tough call. :)
Shmee
8,313
3,177
I would go with the XFX 280, the extra GB should help, depending on games played and resolution of course. Is this a temporary solution until r9 3xx is out? Or would you be using this for longer?
plzhelpimnew
I would be using it for a while more than likely, I have a 1080p monitor and dont plan to upgrade further for quite a while since its less than 8 months old.
I wonder how well either of those cards would take an OC? What card would come closest to a 280x once clocked?
Thanks for the quick reply's!
Subyman
Moderator <br> VC&G Forum
Mar 18, 2005
7,876
32
86
R9 285's can hit around 1100mhz normally, maybe a bit higher. So around a 15% OC. The 280 does about the same. The 1 extra GB is probably worth more to you than the few percentage points more performance than the 285 has. 285 also includes Freesync and Trueaudio support, but I doubt you need those.
If you aren't afraid of used, then you can get an R9 290 for around $200 shipped off eBay. That would be a sizable performance boost.
RussianSensation
19,458
765
Out of those 2 I would take the R9 280 for 3GB of VRAM and lifetime warranty. However, if you can wait, see if you can save up a bit more and get an R9 290 for $240. It's worth it.
A good rule of thumb is that an after-market R9 290 = Reference R9 290X.
At 1080P, R9 290X is 54% faster than an R9 280.
9433
XFX R9 290 is $240 (50% more expensive for about 50% higher performance than an R9 280).
I think half a month or a month before R9 300 series drop, we should see R9 290 for $200-220. That gives you a bit of time to save up from your $175 budget and get at least a 50% performance increase!
Shmee
8,313
3,177
I agree with both Subyman and RussianSensation. Definitely consider an on sale/used 290.
plzhelpimnew
Im going to try and hold out a bit longer (but its not easy!) for the 3xx's - or grab a 290 that has a good rebate.
Thanks guys, much appreciated.
