Need a multimeter that will display PEAK values... please read.
Status
Not open for further replies.
slugg
4,723
80
I'm looking into working on a project that would require a tool to measure and display the peak voltage, current, or resistance in a circuit. The reason why I'm interested in peak values is because this circuit will only be engaged for roughly 100 ms at a time. That's too fast for my nerdy eyes to see and react to with a traditional multimeter ;)
Any recommendations?
PottedMeat
12,363
475
I would ordinarily say just use a Fluke with a MAX/MIN/AVE button... but 100ms? My 112 only displays 4 samples/sec so that's probably out.
Can you get a cheap digital scope?
slugg
4,723
80
Some signals may be even shorter... like 50 ms.
Bobsmith, do you have any experience with Picoscope? Which model would you recommend?
bobsmith1492
3,875
I used one a little but it was an older model. The software was a bit finicky but it did the job just like any oscilloscope.
I'd go with your budget; the cheapest one (the one I linked) will work for your application; it just won't do you any good if you have any high-speed data in the future, that is, anything much over 1MHz.
Status
