Originally posted by: Eureka
Originally posted by: Psynaut
Originally posted by: corkyg
Originally posted by: mpilchfamily
Only real difference between a laser and regular optical mouse is the camera used to track the surface its on.
Not exactly. The main difference is that the conventional optical mouse uses a red LED light source. AS laser mouses uses a laser beam, which has greater resolution and accuracy. No camera is involved. Both have sensors that read the reflected light.
There is also an 'unconventional' infrared optical Mouse made by Razer called the Deathadder, which doesn't produce a visible light. I don't know if it is, or isn't, less accurate than a laser mouse, but it is very popular with gamers and many consider it to be the best mouse available.
That's not optical that's a laser mouse... all laser mice I've seen use an infrared laser, including the Logitech G5 and and couple other generic laser mice.
I've tried a whole array of mousepads, and to be honest, none of them really do anything special. I had one special aluminum and vinyl mousepad that made gliding smoother, but the use was pretty much the same. Right now I'm not using a pad at home and at work I have a gel mousepad, and I barely notice the difference.
