Originally posted by: Denithor
Originally posted by: AmberClad
As far as the second part of your question -- is that referring to the ASRock Conroe 1333? I'm not completely sure about the "FSB1333-CPU will operate in overclocking mode". There seems to be an additional note: "Under this situation, PCIE frequency will also be overclocked to 115MHz."
I have this board--can't even get 10MHz extra speed out of it, even setting the pci-e to async for overclocking. No joy here. Keeping it for a budget build for someone (cost $15 to RMA it, only cost $50 to begin with).
Instead, get AT's
recommendation from their budget build article, the
Gigabyte GA-73UM-S2H based on the GeForce 7150 chipset. This one has native support for 1333 so you shouldn't have any troubles with overclocking.
If you want to stick with an Intel chipset, there is a good-looking
Foxconn G33M that is a bit cheaper and also fully supports 1333.
