A friend wants me to set up a network through his house. It will have some mission critical PCs at one end of the house connected to the router through cat-5 and wireless through the rest of the house.
The house is fairly long, brick/concrete walls so I doubt that a signal from one router would do reach to the other end.
I would still like to try a MIMO router an see how far it goes. The problem is that it would connect to laptops or PCs without MIMO network cards so I don't know if that is an option.
So my next option is to get a wireless router and then run a repeater. It is possible that I might have to use 2 or even 3 repeaters dew to the thick walls. I would prefer to use routers as repeaters and be able to connect wired PCs to them if needed. I believe BuffaloTech has such routers out of the box and Linksys can be firmware hacked for this.
Either way I would like to go to Best Buy or some local store and buy some good hardware if only to test the range it can give me. Can you give any good suggestions for what hardware I can test out and what would be the most efficient way to run this network.
The network is more for internet through cable. So would it be possible to connect a second modem at the other end of the house and have it connect to a wireless router so there would be two routers and either side and clients will find the best one through the house. I want this to be legal so if it is possible, what can I tell Comcast to do to get the second modem to run.
Thanks
Thanks
