Hi.
I have a D-Link DSM-G600 NAS box with a built-in wireless AP/Client. I also purchased used a D-Link DWL-900AP access point. It is only an 11MB/s router, but this thing will eventually be used ONLY for internet access, so speed is not a problem.
Here is my setup.
192.168.1.1 - Linksys BEFSR41 router
| cable connection
192.168.1.2 - D-Link DSM-G600 Network Storage and Access Point
/ wireless connection
192.168.1.3 - D-Link DWL-900 AP (in client mode)
| cable connection through hub (I do not have a crossover cable)
192.168.1.65 - Computer
From a PC connected directly to the BEFSR41, I can ping the DWL. The wireless connection works. The NAS box even reports the connection on its configuration screen.
From the PC at 192.168.1.65, I can ping the DWL. The wired connection to the DWL works. I can also run the management utility perfectly from this PC.
From the router side, I cannot ping 192.168.1.65 (the PC). Note that there is no firewall on this PC right now.
From 192.168.1.65 (the PC) I cannot ping either the NAS box or the router.
Everything SHOULD be working, but it is not. I have all encryption turned off right now.
Any ideas?
Here is my setup.
| cable connection
Any ideas?
