- Sep 21, 2008
- 134
- 0
- 0
ok first off about ram. i dont know what speed to choose but im think ddr2 1066. but i dont know if i can run this actually at 1066. im getting a q6700 which fsb is 1066 and my mobo is the p5q pro. so would i be able to run at 1066 or should i go with 800 or 1000? also if i can run at 1066 i would be getting the Corsair dominator which needs 2.1v but the mobo i think is set to 1.2v to reduce heat. could i change this and if doing so would it can instabilty?
as for the harddrive im getting the samsung spingpoint 1tb. its sata, and the psu im getting is the corsair 550vx. my main question is since the hdd does not come with any cables is there any cables that i would need to buy for this?
thanks for replys!!!!!!
Corsair 550vx Cables in the psu at the bottom of the page.
http://corsair.com/products/vx.aspx
CORSAIR DOMINATOR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel
http://www.newegg.com/Product/...x?Item=N82E16820145197
ASUS P5Q Pro LGA 775 Intel P45 ATX Intel Motherboard
http://www.newegg.com/Product/...x?Item=N82E16813131299
